heater problem
Old Jan 21, 2015 | 04:49 PM
C-Meth's Avatar
heater problem
I have been searching since last night and can not seem to find the answer.
Out of the blue my vent selector stopped working. air is only coming out of the vents. I turn the knob and nothing happens. I live in ohio defroster is like a must right now. does any one have any ideas where to start looking.
I am thinking maybe its a fuse. the ac wont engage either. fan speed works fine and so does temp control. ( I will double check heat control here in a min)
any idea folks?
Old Jan 21, 2015 | 05:00 PM
C-Meth's Avatar
Added note. Temp control is not working and my dis info center is not responding either
Old Jan 21, 2015 | 05:05 PM
Try "mode door". There will be a lot about "blend door", but they are related. There is a door and an actuator. 8,11,7,3 in the drawing.
Old Jan 21, 2015 | 05:06 PM
Well then your added note would make me start looking at fuses.
Old Jan 21, 2015 | 05:15 PM
C-Meth's Avatar
Any ideas which ones might be related ??
Old Jan 21, 2015 | 05:25 PM
Fuse #10, 16 and relay #30 in the inside fuse box location.
Fwiw. All I did is look in the owners manual for the related ones. It should also be labeled on the box cover.
I would go look for my Owners Manual and look, but you could do that, and I wouldn't get cold.
https://www.chevyhhr.net/forums/gene...s-manual-3074/
Old Jan 21, 2015 | 07:26 PM
C-Meth's Avatar
Thanks guys I will start checking. My x took the owners mmanual with her when she left and got her stuff out the car. I had a copy of the it on my laptop but it crashed :/ I thank you guys for the help I will let you guys know asap
Old Jan 21, 2015 | 08:21 PM
C-Meth's Avatar
Thanks guys it was the fuse all went back to normal ty so much for the help
Old Jan 21, 2015 | 10:13 PM
Fwiw. Fuses usually don't blow without a reason. Something drawing too much current or a possible short could be the cause.
I hope it doesn't blow again, but don't be surprised if it does.
The Curly 1
Apr 3, 2020 06:11 PM
Samlor
May 1, 2014 01:15 PM
urbexHHR
Nov 3, 2010 07:00 AM
outlandishhhr
Dec 16, 2009 11:59 PM
budokai140
Jan 4, 2008 02:38 PM
