2008 Chevy HHR Tail lights & Side Yellow lights are staying on
Old Jan 23, 2020 | 08:23 PM
Is the dashboard light sensor dirty ? The one in the top/middle of the dash.
Old Jan 24, 2020 | 08:29 AM
gio89kid's Avatar
Sounds like your running lights are staying on. Assuming bumper/side reflector lights are burnt out.
Could be the blinker/headlight switch on the steering wheel, but it looks like you already changed that.
Otherwise, I don’t know what would fail to have two circuits stay on? Both rear tail lights as if applying the brakes??? and front blinkers not blinking but on full brightness???
Actually, donbrew is right, a short to the hazard switch could do that assuming the switch controls the lights and not the BCM. This would also explain why the side marker lights are not on.
Old Jan 24, 2020 | 09:05 AM
As with everything on the HHR the switch is a sensor that signals the BCM to energize a circuit. If they were stuck flashing the hazard switch controls only the turn signals, if they were not flashing the markers would also be on. I am so confused.
Old Jan 31, 2020 | 07:19 AM
oat0328's Avatar
2008 Chevy HHR 2.2L LS 4 Door Electrical ignition switch removal
Hi, I have a 2008 Chevy HHR and the lights are flickering the taillights are staying on. It was recommended to change this part that labeled in red which is an electric ignition switch. How do I remove it? I removed the screws and tried to pry it out carefully. I can't get it to come out. This is a google picture I have not removed this part from my vehicle it is still intact.
Old Jan 31, 2020 | 07:49 AM
Has the ignition switch recall been done on your HHR.
https://www.chevyhhr.net/forums/gm-r...-recall-60411/
Stop by a GM dealership to have your VIN checked
Old Jan 31, 2020 | 08:17 AM
Or check for yourself: https://www.chevyhhr.net/forums/gm-r...-status-50716/
Who recommended this action? I don't see a connection.
I think the trick is to turn the key to "run". if you insist on it.
Diane Dodd
Jul 8, 2018 07:19 AM
SotongMom
Jun 27, 2016 01:11 PM
kgladish
May 4, 2015 08:09 PM
anthonybeatz22
Apr 13, 2014 12:54 AM
PhoS
Nov 16, 2009 06:26 PM
