Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
My 2008 HHR has a passenger floor water leak. I had the windshield replaced and the technician showed me where the water was coming in. The "butyl patch" is missing along with the gasket. I can't find a " butyl patch" on ebay or part stores. Nor can I find the gasket. Maybe I have the names wrong?
Thanks, that's the piece that's missing and I couldn't find a part number. I could find the cowel water deflector and it showed that part but gave no number.
The 2008 cowl should not look like this 2006 model It should look like this 2010 with smaller opening and no patch This 2006 has a damaged butyl patch
this would definitely leak
I will try again, the 2008 does not need the patch. ONLY 2006.
The water is coming from elsewhere! AC, door conduit, windshield seal, door gasket, sunroof drains etc.
