2010 blower issues
Old Dec 11, 2016 | 04:20 PM
tim597's Avatar
2010 blower issues
Blower motor works as I applied 12 volts to it. All fuses are good under the hood and interior and were checked for power. Replaced four prong relay on interior fuse box. I am getting power to the speed switch, but no power to the resistor block. Is my control panel possibly bad?
Old Dec 11, 2016 | 04:50 PM
Welcome to the site, seems to be the problem
Old Dec 11, 2016 | 06:49 PM
I think a wiring diagram would explain what and where to test. I think you are making a false assumption.
Old Dec 12, 2016 | 05:47 PM
tim597's Avatar
Thank you for the wiring diagram Brew. Back to the garage for more testing.
Old Dec 16, 2016 | 05:26 PM
MrMom's Avatar
Don, How can I enlarge the image to make it readable? I have saved it to my desktop and zoomed in but can not read the notations. 2008 HHR intermittent blower (all speeds) dry interior.
Old Dec 16, 2016 | 06:08 PM
You would have to convince me to do some work. Problem being proprietary software.
The only part you really need is the bottom bit. the important part is that 12V goes directly into the motor, all speed control is ground side.
That's why I'm having trouble figuring out how and where applying 12V to the motor would do anything at all if the fuse and relay are good.
Check your PM.
Old Dec 17, 2016 | 11:57 AM
MrMom's Avatar
Don, Thanks for the heads up. I have my work cut out in the cold and snow near Buffalo NY.
Old Dec 17, 2016 | 06:17 PM
Yes, it's freezing rain across the river from you! Bbrrrrr!
Old Dec 17, 2016 | 09:40 PM
tim597's Avatar
I found I had no continuity from x210 to the blower motor. The grey wire wrap behind the motor had the brown wire pinched. straightened out the wire and retested. Boom! Continuity! 20" of new brown wire and we are back in business.
Old Dec 17, 2016 | 10:33 PM
Congrats on tracking that down.
LuckyLadySD
Jun 12, 2014 02:09 AM
gilbert
Sep 4, 2010 09:50 PM
elvistar
Sep 2, 2010 08:13 AM
jeffros hhr
Jun 26, 2009 07:54 PM
