2010 HHR LT - C0050 RR Wheel Speed Sensor Circuit - How to...
Old Sep 26, 2020 | 10:34 AM
jigsb's Avatar
Thank you all
thank you all, issue has been resolved.
it was a bad hub sensor. It was a real pain to remove the hub cover, had to hammer it out and then even bigger pain to get to the bottom 2 bolts. The access to the two bolts was blocked by the shock spring/coil and it was right in front. Had to jack the spring up to pass the 3/8 extension thru.
Damn really bad design imo, wish it was a replacable sensor like the rest of the cars.
Anyway, happy to see the job thru and save quite some money in the process and that is all thanks to you all.
Cheers all.
Old Sep 26, 2020 | 12:34 PM
But you won’t have to address those fasteners for a long time ! Glad it’s fixed.
Old Oct 22, 2020 | 02:32 PM
hurst2001's Avatar
Cheers all.
I just ran into this and looked up and seen the top plastic part on the hub was cracked and wonder if water got into to it would cause failure? I’m at 144000 miles
Old Oct 22, 2020 | 02:47 PM
Very possible!
DangerBoy
May 31, 2020 06:35 PM
Bob Hayman
Dec 26, 2014 02:51 PM
one_2mny
Maintenance and Upkeep
Oct 31, 2011 06:26 AM
ald
Sep 17, 2011 12:23 AM
