2011 HHR Steering-shifting issues
Old Jul 15, 2024 | 08:05 PM
4 bolts in the fuse box!!!!!!!
Old Jul 16, 2024 | 10:16 AM
Brkdnc's Avatar
re-tightened all the bolts in fuse box, all wires are tight
voltage 12.1 off / 14.3 running in battery
took out this morning for a test drive after tightening bolts no change
hard shift into 2nd gear engine light finally came on
still no speedo or outside temp listed
Old Jul 16, 2024 | 10:21 AM
Bad battery. Should have 12.6-12.8 volts.
Light came on ? CEL ? Then you need to pull the codes.
Old Jul 16, 2024 | 10:54 AM
Brkdnc's Avatar
hit garage ran code
trany rear shaft speed sensor thingy
MotherF*cking small critters ate wires!
Old Jul 16, 2024 | 10:59 AM
So. You have a bad battery. Chewed up wires. And some unknown code that you didn’t post the # for. Sorry can’t help you without the actual code number. Descriptions are useless and sometimes out and out wrong.
Old Jul 16, 2024 | 03:39 PM
Brkdnc's Avatar
Battery is 8 years old still works
chewed wires did all the funky stuff no shift or speedo, temp etc.
Old Jul 16, 2024 | 03:50 PM
Oh. OK. Sorry I tried to help.
I’m out.
califphil
Feb 7, 2024 06:38 PM
dromayr
Maintenance and Upkeep
Dec 23, 2020 11:15 AM
QuickDrawMcGraw
GM Recall Campaigns
25
May 9, 2019 09:48 PM
SnoopHHR
Oct 14, 2018 05:46 AM
budzone
May 16, 2018 10:30 PM
