#4 misfire
Old Jun 11, 2020 | 06:54 PM
Isolated's Avatar
#4 misfire
My 2008 HHR 2.2 has a misfire in #4 only - according to the scanner. I tried switching the plugs and the coil pack but the miss stays at cylinder 4. Is it true that there is no separate
ignition module on this engine? thanks
Old Jun 11, 2020 | 07:37 PM
P0304 code check causes and possible solutions. It might be a dirty injector or loose wires
https://www.obd-codes.com/p0304
Old Jun 11, 2020 | 10:08 PM
Are you experiencing a strange odor of steaming coolant, a loss of coolant, a lot of condensation out the tail pipe or muddy looking oil?
Do a compression and leak down test looking for a bad head gasket or burned valve.
Your 2008 2.2L has individual coil on plug modules controlled by the ECM.
Jfidelh
Mar 26, 2023 04:27 PM
LONALA
Dec 21, 2016 07:53 PM
FatTireBiker
2.2L Performance Tech
Jun 9, 2014 01:56 PM
Cheko0602
Dec 7, 2013 11:45 PM
dzmija
Oct 27, 2013 04:34 PM
