ABS TC code C0035-18
Old Oct 1, 2019 | 05:36 AM
ScareDe2's Avatar
Front left speed sensor - Low signal amplitude. all 4 bearings are brand new and came with the ABS included. I delete the code with the scan tool and just after the first acceleration, on the dash board the ABS and TC lights appear. Any idea?
Also, on the scan tool, the code reads as "history" instead of "actual", which I find strange.
Old Oct 1, 2019 | 07:14 AM
Inspect that wire harness for loose connection and pinched wires.
Old Oct 1, 2019 | 08:28 AM
History will clear after 100 good key cycles.
My guess is a defective LF hub.
Old Oct 1, 2019 | 09:49 AM
ScareDe2's Avatar
Hi sorry but what is a key cycle?
Also, would it be a good idea to just swap the left bearing to the right to see if the code appear to the right instead of the left?
Old Oct 1, 2019 | 10:14 AM
Key on-Key off. Kinda like whacks on- whacks off.
Depend on if you have a VOM.
Old Oct 1, 2019 | 03:13 PM
You could go to the trouble of swapping the hubs as you suggest , then order a new pair , and keep the good one for a spare.
PM Art he has a pair for sale
the ad has expired but he might still have them
https://www.chevyhhr.net/forums/inac...ht-pair-61884/
Old Oct 5, 2019 | 04:42 PM
ScareDe2's Avatar
I was in the process of swaping the left hub to the right and in my bad luck I solved my problem. Was using the wheel attached to the hub to pull it out and forgot to disconnect the sensor cable. The ring sensor separated from the hub.... and I replaced it with an old one I had at hand in the garage. No more codes lol. Did not cost me a penny. Very glad. I used a piece of wood pressed against the old ring and hit it with a hammer for it to take place around the hub.
Old Oct 5, 2019 | 05:54 PM
So problem solved? If so great. I wouldn’t leave it like that . But it’s up to you.
Did you PM Art?
Old Oct 5, 2019 | 07:34 PM
ScareDe2's Avatar
Did you PM Art?
No because in the first place I was looking for a working front hub while Art was selling rear ones.
Yes ABS problems solved.
Retrokid
Jul 11, 2019 06:13 PM
questionMARK
Oct 21, 2016 02:27 PM
rjdelapp
Jul 26, 2012 10:56 AM
helhedded
Mar 22, 2012 06:55 AM
5speed4
Mar 13, 2008 09:12 AM
