Abs and traction control light
Old Nov 16, 2024 | 11:22 AM
greg8453's Avatar
Originally Posted by Jaksback
So this all this to say that the abs and TCS lights may be coming on occasionally due to my timing belt wearing out and causing debris in the vvt solenoid? Or did I miss something?
Next question is how difficult us it to replace the belt (my research is that the 2010 2.4l has a belt and not chain) and how long of a fix is it i.e. 1 hour 2 hour all day?
Your VVT has ZERO to so with the ABS. Timing chain/belt has ZERO to do with it. Scan the abs module and find which wheel is having a problem.
Old Nov 16, 2024 | 12:37 PM
Actually an ABS problem can be resolved with replacing the VVT solenoids, the failed solenoid turns on TC and ABS light , a P0014 triggered mine
Old Nov 16, 2024 | 12:41 PM
Lonwane's Avatar
Jaksback,
I'm not sure where you are doing your research but, ALL Ecotech engines have timing chains.
As for the amount of time to change,
how good of a mechanic are you?
Mine took 2 days but I'm 67 and was in no hurry to get it done.
Old Nov 16, 2024 | 01:29 PM
Jaksback's Avatar
will the CEL come on and stay on with this code? Will this code show on a regular obdii reader?
next stupid question how difficult/involved is changing a vvt solenoid?
is this video a good/accurate video for doing my vvt replacement?
Old Nov 16, 2024 | 01:36 PM
Jaksback's Avatar
Originally Posted by Lonwane
Jaksback,
I'm mechanically inclined but lacking good location, time and no other vehicle to drive scares me that I couldn't get it done in a timely manner to go to work the next day. So I may have to have a shop do it, damn!
I did my search on chain or belt but I guess since I have a metal cover it's a chain according to what info it gives
Old Nov 16, 2024 | 02:21 PM
GoOgle lies! Ecotec engines have timing CHAINS.
True the timing and VVT have nothing to do with ABS and traction. But, if either malfunctions the computer turns ABS and traction OFF resulting in the warning lights.
Old Nov 16, 2024 | 03:53 PM
VVT solenoids have one 10mm bolt each careful with the electrical connections.
Old Nov 16, 2024 | 03:58 PM
Jaksback's Avatar
again I ask, will the CEL come on as well?
Old Nov 16, 2024 | 04:04 PM
Jaksback's Avatar
On the video i showed above they said the intake vvt solenoid was a 10mm ans the exhaust was an 8mm. It doesn't matter either way, the intake vvt solenoid is on the forward side and exhaust vvt solenoid is closest to the back firewall...does this sound correct?
Old Nov 16, 2024 | 04:17 PM
not always
