Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
Probably going to be a stupid question. But should I by genuine g? M? Part, or do you think the autozone parts will be comparable?
or these from amazon:
Buy ACDelco solenoid valve unless you think they might clog up, then consider AutoZone Duralast with the lifetime warranty. Don’t even think about WhoNow? brands, which are famous for failing in a week.
I did use a Dorman once in a pinch, dunno if it lasted cuz I sold the car.
BTW, generally speaking, Electronic Stability Control (ESC) gets disabled when there are certain engine codes, because it takes control of the throttle. It’s to protect and engine with problems, limp mode in particular. Dunno the specifics with HHR..
So. Looking back thru the OP’s posts in this thread, I don’t see any mention that he ever pulled the codes on his car. Guess he’s just going to throw some solenoids on there to try and fix his traction control and ABS lights ?
He could be barking up the wrong tree so to speak.
Get those codes pulled. Even if the CEL isn’t on there may be some stored codes.
