Abs and traction control light
Old Nov 16, 2024 | 04:35 PM
Exhaust is close to the firewall, intake is close to the radiator , here’s a how to thread with part number’s
https://www.chevyhhr.net/forums/how-...13-14-a-28779/
Old Nov 16, 2024 | 04:36 PM
In layman’s terms.
The solenoids are color coded. Gray and black tops. Put the new ones in the same way the old ones are by the color.
Old Nov 16, 2024 | 06:27 PM
Jaksback's Avatar
Probably going to be a stupid question. But should I by genuine g? M? Part, or do you think the autozone parts will be comparable?
or these from amazon:
Old Nov 16, 2024 | 06:34 PM
Jaksback's Avatar
this thread doesn't list what year to the part numbers
Old Nov 16, 2024 | 08:06 PM
The GM part numbers are all years HHR with VVT
12679099 Intake and 12679100
for the exhaust
Old Nov 16, 2024 | 08:35 PM
  #26
Jaksback's Avatar
for the exhaust
are the ac Delco gm original equipment solenoids from autozone ok?
Old Nov 16, 2024 | 09:04 PM
  #27
Wow. That’s expensive. Have you tried an online search ? I know when I got my solenoids from RockAuto they were a lot cheaper.
Old Nov 17, 2024 | 12:14 AM
  #28
Jaksback's Avatar
Heck with amazon and autozone, got the dorman ones like was in the parts list from the thread above for 1/2 the price.
Hope the dorman's plug is correct as it said one member saying the plug didn't fit right. Will know I guess when I go to install it. Wish me luck huh?
Old Nov 17, 2024 | 08:09 AM
  #29
PulpFriction's Avatar
Buy ACDelco solenoid valve unless you think they might clog up, then consider AutoZone Duralast with the lifetime warranty. Don’t even think about WhoNow? brands, which are famous for failing in a week.
I did use a Dorman once in a pinch, dunno if it lasted cuz I sold the car.
BTW, generally speaking, Electronic Stability Control (ESC) gets disabled when there are certain engine codes, because it takes control of the throttle. It’s to protect and engine with problems, limp mode in particular. Dunno the specifics with HHR..
Old Nov 17, 2024 | 09:31 AM
  #30
So. Looking back thru the OP’s posts in this thread, I don’t see any mention that he ever pulled the codes on his car. Guess he’s just going to throw some solenoids on there to try and fix his traction control and ABS lights ?
He could be barking up the wrong tree so to speak.
Get those codes pulled. Even if the CEL isn’t on there may be some stored codes.
