ABS warning light? It ain’t always the ABS sensor!
Old Jul 11, 2019 | 05:57 PM
Blue_SS's Avatar
OK, well, I would say it's that calculated amplitude that matters then. The module sets a base level high current and saves it. Once corrosion or a pinched wire enters the playground, those peaks are unexpectedly low, and a fault is set. We are saying the same thing.
Some of the how is definitely reserved for the EE types... I was surprised they measured current and not voltage. That's where my knowledge was at.
There's also the possibility that older ABS modules did this differently. I was just trying to explain it. Maybe I made it more confusing.
Old Jul 11, 2019 | 06:13 PM
AC by it's nature is digital; 0 or 1. The rise and fall part of the wave is basically ignored. Digital circuits actually see 5V or less than 5V. The 5V ref and low ref where low ref is usually digital ground but could be 4.9V if that was easier.
Gr8WhtBuffalo
May 27, 2015 04:33 PM
manicrodder
May 10, 2015 11:45 PM
JuMPy
Apr 15, 2011 11:34 AM
HHR Forever
Nov 25, 2006 09:09 AM
DJNateGnau
Nov 6, 2006 04:22 PM
