AC Condensate leak in car
Old 06-04-2013, 04:25 PM
wireskinner's Avatar
I just developed a water leak, inside passenger side. It appears to be an evaporater condensate leak. The car is also leaking water outside as designed. Any ideas?
wireskinner is offline
Old 06-04-2013, 04:32 PM
Radco's Avatar
the drain hose may be partly blocked or cracked. The drip tray should be fine.. Also if you have a blocked air filter the poor air flow will Ice the Evaporator coil! Low Freon will also cause icing on the A/C line's . I would start with the cabin Air filter and not sure if you can see the drip tray of drain hose from under the dash, I am new to the HHR. Good luck and please post what you find! Also this has been discussed before so also try the search box! Ill see if I can find anything! Im sure the gear heads will post soon.
Rich
Found some info
https://www.chevyhhr.net/forums/show...ssenger+carpet
Radco is offline
Old 06-04-2013, 04:45 PM
Along with the threads Rich found for you (), give this thread a read too....
https://www.chevyhhr.net/forums/problems-service-repairs-42/water-dripping-onto-floor-36470/
It covers the condensate drain and its location.
P.S. to the forum!
843de is offline
Old 06-04-2013, 09:00 PM
Radco's Avatar
Oh yea WELCOME to the forum
Radco is offline
1970judge
08-14-2015 05:47 PM
gschroed
01-29-2014 07:24 AM
hurst2001
08-04-2013 04:45 PM
blomb
07-03-2008 11:30 AM
pobryne
06-05-2008 09:47 PM
Quick Reply: AC Condensate leak in car
