Air Bag Light On
Old Aug 26, 2020 | 09:05 AM
  #91
haX0r's Avatar
Is this module a node on the CAN bus? (What's the node address?) I had been pondering removing the pass seat, but this latest adventure tells me its not so simple.
But if its a CAN bus node I might be able to whip up a 'test pipe' (showing my age) with a PIC microcontroler. (Some have built in CAN interfaces)
I have a few CAN bus hacking tools.
Old Aug 26, 2020 | 01:47 PM
  #92
If it is "historic" it does not matter, that just means it happened one time and is now fixed.
Go back even farther to 10Base2. Can bus is that simple. No address just 2 terminating resistors One in the ECM and one in the BCM.
No, the PPS is not on the bus, the SDM is.
Old Aug 27, 2020 | 07:58 AM
  #93
haX0r's Avatar
CAN bus certainly does have addresses. The 10Base2 is just the layer 1 aspect (But I'd say its closer to RS-485/422). The CNC lasers I service that have CAN bus, each node has an address. Need them so they know who's asking for what. If a command or data is just blindly broadcast how would anything know what it is and where it came from and how to react? There is also a 'master' node too.
But moot for me since the PPS isn't on the bus directly.
Old Aug 27, 2020 | 09:45 AM
  #94
Here is a vid of one of the guys that developed the GMlan.
https://www.chevyhhr.net/forums/how-...can-bus-56781/
Old Dec 25, 2020 | 04:58 PM
  #95
Kyle Smith's Avatar
Service air bag
Originally Posted by joejet727
I got a Problem with the Service Airbag Light coming on and going off. Sometime it stays on for weeks. I have a 2009 HHR LS 2.2 L. I was told there is a recall out there to Replace the Airbag Module. If there is Please help me find out the recall Number to get it repaired. Thank you : JOE
Here's one I tried out of frustration, I loosened the tilt wheel lock. Slamming the steering wheel up and down 5 or 6 times...Hooray! The light went off!!!!!
Old Oct 6, 2021 | 04:14 PM
  #96
Cheap Guy's Avatar
Had this issue with mine when I bought it, in fact I used it as an excuse to lower the price. Like shown in this thread, I went into the passenger kick panel, sprayed the yellow connector with electronics cleaner really good and followed up with dielectric grease. Did the same for the connectors under the seat just in case. So far it's been a couple of weeks and no issues. Once again, thanks for this forum for saving me bucks because I didn't not want to mess around with the local chevy dealer who wanted $150 to reprogram my keys when it was just the buttons on the fob that needed replacing.
Old Oct 6, 2021 | 04:47 PM
  #97
reprogramming keys is free! Look in your Owner Manual.
Old Oct 6, 2021 | 06:46 PM
  #98
Cheap Guy's Avatar
My bad - meant the fob, not the key. One wasn't working at all and the other worked intermittently. Turns out the electronics were good, it was the rubber keypad. Simple R&R with the parts from a $14 Amazon replacement.
vogtrj
GM Recall Campaigns
12
May 3, 2021 04:54 PM
Calebs0615
Jul 17, 2020 09:55 PM
Airfoto
Aug 23, 2016 01:48 PM
Teambenandrosie
Apr 15, 2014 04:38 PM
cubz
May 16, 2012 12:24 PM
