Air Condition varies
Old Jul 14, 2010 | 02:58 PM
Laco's Avatar
It shouldn't blow hot air immediately, I know if I'm running the AC and shut it off while leaving the fan on, it will still blow cold air for several minutes...... I know that's not an auto shut off because of WOT, but the same should happen, I would think.
I'm sure thats correct. When the compressor is cut off, for any reason, the evaporator is still cold and will not warm instantly, so yes you will continue to feel cold air for some period of time. I would think less time if the OAT is 105 degrees, than if it was 78 degrees.
Old Jul 15, 2010 | 01:09 PM
txbass06's Avatar
Originally Posted by Laco
Definately not normal. Mine stays cold regardless of my demand for power, which is as it should be.
Mine's the same way. Just did a few WOT pulls (30 to 50, 30 to 70, and 0 to 70) and didn't notice a change in a/c output whatsoever
working on it
Maintenance and Upkeep
34
Feb 24, 2013 06:41 AM
preciousayana
Aug 3, 2011 06:57 AM
Kevin Schneider
Apr 3, 2009 07:09 PM
Cyclic Hardover
Jul 8, 2008 03:21 AM
coolsurf
Sep 3, 2006 11:03 PM
