Airbag light
Old Oct 15, 2013 | 07:03 PM
uncle jerry's Avatar
Airbag light
Hi. I have a friend with a 2008 HHR. she says the airbag light comes on and off. When it comes on the engine stops. she waits a few min, and it starts back up and will go for a little while before doing it again. any Idea where I should start?
Old Oct 15, 2013 | 08:04 PM
Snoopy's Avatar
You should start your own thread with this question, you will probably get more responses that way.
Besides it is a completely different request unrelated to this thread.
Maybe one of the Moderators.......???
Old Oct 15, 2013 | 08:36 PM
Lucky's Avatar
First thing I would do is get the codes checked. The problem is some code readers won't read air bag code but it's worth a try. I would expect to see communication code of some sort weather its in the PCM BCM or air bag module. The problem could be a power feed issue so check the under hood fuse box for loose connections and or fuses.
Old Oct 15, 2013 | 11:50 PM
As Lucky pointed out, some code readers aren't set up to read codes connected with the SRS/Airbag system.
Unless you have experience working around, and with, SRS components, your best bet is to have it checked out by the dealer or a qualified technician.
Old Oct 16, 2013 | 09:27 AM
Uh, if the motor stops running when the airbag light comes on, wouldn't you think that just maybe there is some DANGER involved? Maybe she should think about having a qualified airbag technician or a GM shop look at it be she gets killed.
Teambenandrosie
Apr 15, 2014 04:38 PM
befisher77
Aug 15, 2012 08:51 PM
cubz
May 16, 2012 12:24 PM
pstar
Feb 23, 2011 07:51 PM
Grimsby
Jun 17, 2010 12:59 AM
