Another blower motor issue
I would advise something more rigid like sheet metal or thick plastic. The reason the butyl would fail was the seal would detach and the butyl patch would sag into the hole. Yours may do that over time with that rubber patch.
Okay, the resistor and blower motor came in and guess, what,,,,, still does not work.
With the connector actually connected, I am getting 12 volts going to the orange AND brown wire each and individually .
Looking at the poor schematics I found online, which I could be wrong, the orange wire goes to the resistor pack and I am led to believe that it should be grounded? Because it looks like the resistor pack supplies ground but again I could be wrong. I have tested the BCM3 fuse and the HVAC relay, besides, I have voltage going all the way up to the blower.
A bad blower out of the box perhaps? Should I supply 12 volts to the brown side of the terminal and ground to the orange side perhaps? Opinions please
