antifreeze on oilfill cap
Old Feb 23, 2016 | 07:37 PM
mister hhr's Avatar
He never mentioned a red light is that a low coolant level warning? No idea on coolant I will have him check on that thanks for the help.
Old Feb 23, 2016 | 08:03 PM
No, if the engine does not warm up as quickly as the computer wants it to it will throw a code and a CEL. The A/C will not work either.
If the coolant is really low the gauge may give a false low.
You did not say what year car, if it's a 2006 it will have a surge tank instead of a recovery tank.
These days NOBODY bothers to check the coolant or oil.
If you need an Owners Manual follow the link in my sig.
Old Feb 23, 2016 | 08:58 PM
mister hhr's Avatar
Its titled as an 08 but was built in 07 cel light is on he had the code read I believe it was code 128 not sure though.
Old Feb 24, 2016 | 07:10 AM
There is a broken t-stat, or something else going on in the coolant.
After that gets fixed the A/C will magically start functioning!
Old Feb 24, 2016 | 11:48 AM
Code P0128
http://www.obd-codes.com/p0128
And instructions! A simple job. Please use Dexcool and a new AC Delco thermostat!
Don't waste your time and money on aftermarket stats, they do not open fast enough to satisfy the ECM hence the code!
https://www.chevyhhr.net/forums/how-...l-p0128-24493/
jdjaa1959
Maintenance and Upkeep
Nov 29, 2015 04:30 PM
Gsus
Jul 15, 2014 10:51 PM
06SILVERLT
0
Aug 6, 2010 01:22 PM
partspeddler1
May 19, 2010 06:50 AM
HHRcheater
Nov 8, 2007 03:10 PM
