bad dash rattle
bad dash rattle
Hello, I am new to the forum and wondering if anyone else is experiencing a bad dash rattle that appears to be on the drivers side. I hear it the loudest under heavy down hill braking. It appears to subside when the steering wheel is turned to the left or right which makes me think it has something to do with the steering link. Its very annoying and seems to be getting worse. Any help would be appreciated.
Sorry about that. Its a 2011 HHR LT with 93,500 miles on it. That fact that the rattle goes away when you turn the wheel left or right make me tend to believe it has somthing to do with the steering link somewhere. I took the bottom of the dash apart and drove around grabbing stuff under there to try to find it. It sounds like its right behind the speedo or in that area. But i know sound can travel and fool you sometimes as well.
That would point toward hub/bearings. But could be the intermediate shaft. I thought you said you read the link?
Vibration in the suspension is causing something to rattle. Look for the cause not the effect.
The Old Guy
02-04-2012 10:42 AM
