Blower quit today--- for a few miles then working again
Old Dec 15, 2020 | 01:04 PM
Rocket Dawg's Avatar
2011 LS model Blower stopped working ( 28 degrees, burrr) All speeds. After about 10 miles it came back on. All speeds up and running again. What should I look for? Dont need this to happen again. thanks I did a search and it has 100's of posts with the word blower in it, didnt find quite what i was looking for.
Old Dec 15, 2020 | 01:43 PM
It could be loose wires, the resistor is giving up (doubtful) the blower fan is giving up ( could be) or the dash control panel is on it’s way south ( again could be ) or it’s a loose fuse # 10 and 16 or relay #30 in the console fuse panel
https://www.chevyhhr.net/forums/gene...r-57650/page2/
Old Dec 16, 2020 | 08:53 AM
Thanks, I'll get at it this afternoon and report back. Also thanks for the link. Planning on turning the key on and then going after fuses/relays and wiggling wires. Yesterday I rotated switch multiple times with no response. Car has been just about perfect for 199k. Hoping this is an ez fix.
Old Dec 17, 2020 | 08:47 AM
Yesterday didn't go quite the way I intended. 28 degrees again. Started the car and again no blower on any speeds. Rotated the speed control knob 7 or 8 times and still nothing. Drove the car less than 1/8th of a mile and the blower came to life again. Drove it about 40 minutes and it worked perfectly the rest of the day. Pulled it inside and went thru the fuses,10 & 16 and #30 also checked connections on the blower itself. No problems and it didnt stumble at any point while wiggling wires etc.. Im keeping the panel for the motor off so that when it happens again, I can tap the blower with a screwdriver handle and see if it comes to life. It seems to be temp related at this point. I didnt hit any bumps in the road when it came to life yesterday, i was probably going less than 15 mph on a smooth road. I also checked the fuses under the hood and everything looks nice and clean, no corrosion. My guess is the motor itself. I'll work at it again this afternoon and see what I come up with. Any thoughts? thanks again for a great forum. Very helpful people here.
Old Dec 17, 2020 | 10:05 AM
Okay, just went out and turned the key on and its working today. I'll check the connections on the back of the switch today.
Old Dec 17, 2020 | 10:25 AM
Keep at it, you’ll find it! Sometimes the blower motor stops in a dead spot and it can come back to life , engender with the slight vibration of driving slowly.
Old Dec 17, 2020 | 11:30 AM
At 199k it could be time. A little history--- Car purchased in 2014 w/ 155k ( 249 k) Probably 1000 miles a week for its first 3 years. Since that time only 45k added. Its been a trooper and dependable.
Old Dec 19, 2020 | 09:26 AM
Quick update. It's been working fine since wiggling wires and pulling fuses. I put a touch of di electric grease on the fuse blade.
Old Jan 17, 2021 | 11:45 AM
1 month has gone by and its been perfect. Easiest fix ever, for me.
Old Jan 17, 2021 | 02:51 PM
Shhhh, you’ll wake the beast!
Lee3333
Sep 15, 2018 12:48 AM
jdburruss
Jun 11, 2014 07:51 AM
deve
Jul 28, 2013 10:09 AM
cmp4001
Nov 30, 2010 12:21 PM
Orange1
Mar 14, 2010 06:08 PM
