Brakes
Old Nov 14, 2011 | 05:47 AM
marylandmike's Avatar
Brakes
I was leaving work yesterday. Started car, backed out and started forward. A lady steped out and I had to stop short but the brakes didn't react. They didn't push down right. I had to forces the brakes down, which wasn't easy. They didn't even feel like non antilock brakes. I didn't hit her. They pulsed and felt "thick" for another 50 feet then worked normally. Any ideas
Old Nov 14, 2011 | 07:35 AM
If it's an SS, there is a TSB involving vacuum pump or reservoir.
Old Nov 14, 2011 | 12:00 PM
Reply
marylandmike,
Have you seen the dealer for this problem?
Evan, Chevrolet Customer Service
Old Nov 14, 2011 | 03:10 PM
it's an SS...I'll look for the bulletin Thanks, Mike
Old Nov 14, 2011 | 03:37 PM
I have 28,000 miles, would these be under waranty?
Old Nov 15, 2011 | 01:08 AM
IgottaWoody's Avatar
Welcome to the SS brake syndrom club.....do a serch and u will finds all kinds o story on this quirk
Old Nov 15, 2011 | 06:54 AM
pitbull76's Avatar
If the car is less than 36 months old it would be warranty; if not you could try asking for assistance from GM as it is a known issue, but who knows if they would help or not.
Old Nov 15, 2011 | 02:24 PM
RE: marylandmike
marylandmike,
Brakes are not normally under warranty,they are known as a wear and tear item. You could check with your dealer to see what they can do. Let us know what you find out. Thank you!
Old Nov 15, 2011 | 02:54 PM
Originally Posted by ChevroletCustomerService
marylandmike,
Evan: You might need to do a little research on the HHR SS brake problems that have been documented by Chevrolet. There is a TSB or such that deals with the SS brake vacuum issues. It covered the 2008 and early 2009 models.
The OP appears he could have an issue with this based on his desciription and some of the readers answers.
Oldblue
Nov 24, 2013 11:18 AM
ImNewHere
Maintenance and Upkeep
20
Aug 4, 2012 02:12 PM
agrandad
Feb 7, 2012 11:13 PM
mrarff
0
Jan 7, 2011 08:15 AM
