Brakes not working
Old Mar 16, 2015 | 02:56 PM
lafinests213's Avatar
Brakes not working
i have a problem with my brakes...
i have a 2006 HHR 2.4 2LT i recently bought a 2009 HHR SS so am going to sell the 2006 HHR. in the 2006 i have the Brembo brakes but since am going to sell it i swapped out the brembos for the stock calipers. once i did that i bleed the brakes but the brake peddle goes to the floor so i tough i might have not done the right procedure. so i took it to the dealer. dealer said it was the master cylinder and brake booster. but it was working just fine a day ago but ok. dealer wanted about 1400 to fix it.. so i said **** no the parts are about 200. so i bought the part and i changed the brake booster and the master cylinder but guess what same issue. has anybody run in to this problem. any info would be great.
Old Mar 16, 2015 | 03:13 PM
Look at all the brake fluid lines, fittings and hoses for leaks.
Check the calipers for leaks. Did you bench bleed the master cylinder?
Old Mar 16, 2015 | 03:19 PM
Re check all fluid lines fittings and hoses for leaks.
Did you bench bleed the new master cylinder!
Man, that MagnaFlow muffler looks very familiar!
Have a look at the rear brakes cylinders
There has to be air in the system or a fluid leak.
Old Mar 16, 2015 | 03:29 PM
i actually took the car to pepboys to get it bleed so ill post back with the results
Old Mar 16, 2015 | 08:11 PM
Lucky's Avatar
Does the car have abs?
ezrider
Jan 30, 2015 07:35 AM
Oldblue
Nov 24, 2013 11:18 AM
JCJSS
Nov 3, 2013 06:21 PM
mrarff
0
Jan 7, 2011 08:15 AM
