A/C growl
Old Jul 16, 2012 | 07:12 PM
  #31
Snoopy's Avatar
Originally Posted by Alzonie
It doesn't necessarily. The noise in mine came back, then they replaced the compressor (This was about 3 or 4 years ago) but the growl, whine, whatever, came back again last summer, especially when it got over 105 outside. This year it does it whenever the A/C is on. Dealer won't change it again as long as the A/C is still cooling, so I have to put up with the annoying noise unless I want to pay for it myself, or it craps out!
You're speaking of 2 different parts. You mention the COMPRESSOR....the fix is for the CONDENSER AND EVAPORATOR. It does work as many have testified to. Including me (still NO GROAN/GROWL after 6 years).
Old Jul 18, 2012 | 05:30 PM
  #32
alexrckid's Avatar
possible final installment..
ok...here we go....."growl" fixed yesterday.. local chevy did the compressor hose/evaporator tubing/bracket TSB fix............had them save the old parts so that i could compare. not much difference(seems like same hose/tubing od's) but...the BIG difference is that there is a section of flexable/RUBBER hose in the compressor line(running parallel to the firewall) that was not in the original piece. the retrofitted "mounting bracket" is to keep the compressor line in place considering the flexable hose section rather than a length of solid tubing. anyway...fixed, quiet and i'm a happy, COOL guy..........
Bigpatshhr
Feb 26, 2014 01:07 PM
Bigpatshhr
Nov 1, 2013 04:30 PM
alexrckid
Jul 14, 2012 10:25 AM
dustymulette
Feb 5, 2010 02:53 PM
pitbull76
Sep 30, 2008 04:59 PM
