cannot fix evap po449
Old Jul 27, 2015 | 05:56 PM
Itzschuster's Avatar
I have a 2008 HHR SS that i bought just recently, and a eval code was up for the the evap control module, so i replaced that and the code went away for like 2 Hours and then came back up, i have power to the solenoid but i do not know if it has a good ground, because i do not know were that ground goes too to be able to test it, and can not find it anywhere. Any thoughts would help and has anyone had this problem before?
Old Jul 27, 2015 | 06:11 PM
Can't you check the ground via the end of the connector and any other nearby ground?
ps: the code is p0449, not po449
Old Jul 27, 2015 | 06:35 PM
i might but i can test the harness up until the point it goes into to cab.
Old Jul 27, 2015 | 08:41 PM
You replaced the one next to the gas tank, right? The rubber seal sometimes does not like being changed, that's the first place to look
P0449 in the SEARCH box yields lots of links.
Old Jul 27, 2015 | 09:12 PM
yes one by gas tank
Old Jul 27, 2015 | 11:41 PM
Lucky's Avatar
Give this thread a read. https://www.chevyhhr.net/forums/prob...49-code-20547/
Old Jul 28, 2015 | 12:17 AM
Good advice and a good thread to point to OP towards, thanks Lucky.
Old Jul 28, 2015 | 07:52 AM
I'm with Whopper trace back and check the ground wire and harness, and Don, check the seal
tomdel50
Jun 26, 2015 08:46 PM
Snoopy
Maintenance and Upkeep
7
Jul 13, 2013 11:02 PM
Diskokid
Nov 11, 2012 01:33 PM
asanti
May 29, 2011 03:29 AM
