car not moving when in drive
Old Oct 7, 2018 | 12:48 AM
antiasinine's Avatar
car starts up, but will not drive or accelerate when in gear. at first car or engine would rev up when gas was pedal was pressed but would not accelerate or move more than a crawl or inch by inch, even if I pressed down on the gas pedal. now when car is started it turns on, battery is good, but won't turn over. and flutters when the gas pedal is pressed.
also, initially, when car was turned on and in reverse the brakes wouldn't work or would not engage and stop car. and now NOTHING besides battery, is working
Old Oct 7, 2018 | 01:15 AM
Welcome to the forum.
Well, sounds like a real problem there with your 2007 HHR. How many miles on it, and has it been properly maintained with regular oil and filter changes etc.?
You say it starts and turns on, but won't turn over - and that does not make sense at all.
You also say "now when car is started it turns on" - and later say "and now NOTHING besides battery, is working". What do you mean by that, as it doesn't make sense either.
So I have to ask..... is the check engine light (CEL) on? If so, have you had the error codes read? How do you know the battery is good? Have you had it load-tested?
Old Oct 7, 2018 | 08:34 AM
Welcome to the site, x2 about the CEL and the battery, even 12.4 volts can be to low.
Old Oct 7, 2018 | 03:19 PM
Cat Man HHR's Avatar
X2 about making your statements clearer.
Old Oct 7, 2018 | 03:46 PM
With the User name that the OP has,,,,,,,,,,,,are we being trolled ???
Old Oct 7, 2018 | 05:32 PM
Most likely...
Old Oct 7, 2018 | 06:12 PM
I don’t think so, her names Anita
Old Oct 7, 2018 | 11:47 PM
If she doesn't come back by tomorrow, we'll likely just close this thread.
jollymon
Sep 17, 2018 04:18 PM
RBodeman
Nov 16, 2012 07:09 PM
843de
Jun 4, 2012 09:44 PM
ZTony8
Nov 3, 2011 09:44 PM
Grimsby
Mar 25, 2011 05:36 AM
