Car shuts off when I press the brake
Old Aug 29, 2017 | 11:45 PM
Mv60's Avatar
The car turns on and everything runs normally until I press the brakes. As soon as I press down, it shuts off. Most of the time I'm able to immediately turn it back up back it'll sometimes need a minute or two to turn back on. Usually when the lights inside turn back on.
I'm in Houston so I had some water, somehow, get into where the spare and battery are. Maybe an inch and a half of the battery got wet but I don't think that was the problem. Everything else seems to be working fine.
Anyone else had this problem or know the solution?
Old Aug 30, 2017 | 02:18 AM
In Houston, during a flood situation due to the storm? Are you telling the whole story here - you say maybe an inch and a half of the battery got wet? Was there also water inside the passenger compartment? Did the starter get wet?
If you are saying it was actually involved in the high water flood tis time to contact your insurance company.
Old Aug 30, 2017 | 07:12 AM
Welcome to the site, X2 when the flooding subsides and the car drys out, maybe it'll work again but most likely not.
Old Aug 30, 2017 | 08:48 AM
aradmahogany's Avatar
Wouldnt that mean that they would have had to drive through at least a foot of water if not more for the water to be level with the bat in the back? That would put alot of other components under water as well if that is the case.
Old Aug 30, 2017 | 08:54 AM
That much in the rear battery/spare tire area would short out the ground and the master fuse back there , very plausible.
But I can't see it from here.
Old Aug 30, 2017 | 08:56 AM
Looks like we need to DIVE deeper into this one (sorry, too soon?)
Old Aug 30, 2017 | 08:57 AM
A little!
Old Aug 31, 2017 | 02:25 AM
His original post, which he deleted, made no mention of water intrusion - "The car turns on and everything runs normally until I press the brakes. As soon as I press down, it shuts off. Most of the time I'm able to immediately turn it back up back it'll sometimes need a minute or two to turn back on. Usually when the lights inside turn back on.
Anyone else had this problem or know the solution?"
I suspect we won't hear back from him.
Old Aug 31, 2017 | 07:48 AM
Then let's close this
Lee3333
Jan 11, 2012 10:02 AM
El_Guapo
Aug 9, 2006 12:28 AM
JonyyB
Apr 17, 2006 02:38 PM
