Car sputters and hard to crank on a cold start.
Old Nov 18, 2013 | 04:00 PM
mcdavidhome's Avatar
Hello everyone. I have a 2011 HHR with only 32000 miles. My car is sputtering after cranking it only on a cold start. My check engine light is also on and the error code is (P 0172). When I took it to the dealership for a diagnosis, they tell me that the fuel trim is rich and that my alcohol content from the gasoline I'm using is very high, over 65% and that is what's causing my car to sputter on a cold start and my check engine light to come on. Of course that kind of problem want be covered under the manufacturers warranty.
They claim in order to fix the problem, they would need to clean the fuel injectors and the throttle body. After cleaning all of that the computer would have to be programmed also. I'm sorry but that sounds like a bunch of bull and I'm not believing that story without seeking a second opinion first.
Has anyone ever had this kind of problem?
Old Nov 18, 2013 | 04:12 PM
A few people have had the same code pop up. Did you use the Search Tool at the top of the page to search for p0172? One that I just read mentioned that they cleaned the MAF sensor and the problem cleared.
https://www.chevyhhr.net/forums/problems-service-repairs-42/more-cel-p0172-44575/
Did you fuel up with e85 instead of regular gas? Is your car e85 capable?
Old Nov 18, 2013 | 04:21 PM
Snoopy's Avatar
X2.....
before allowing the dealer to proceed I would use up as much of the fuel, that is in the tank, as possible and refill with a name brand making sure it is AT LEAST 87 octane then use Seafoam, or similar product. Might be required to do this a couple of times to get acceptable results. And of course do as suggested above.
Look at the threads that are listed for your problem in the "Search" field.
Of course you may also have a fuel pressure problem, which creates additional service.
Do you know how the dealer determined that your current fuel is 65% alcohol?
Old Nov 18, 2013 | 05:10 PM
Check your PM, and sorry for the late reply.
To me it sounds like a dealer that's bypassing the proper diagnostic procedures and going for your wallet with the classic "upsell" of a "Fuel System Service".
To me, the first step is always suspecting a dirty, failed, or loose MAF sensor.
http://www.obd-codes.com/p0172
Old Nov 18, 2013 | 05:14 PM
A. they can tell the alcohol % with a scanner.
B. P0172 Can mean: bad O2 sensor, exhaust leak, bad catalytic converter, broken flex pipe among other things.
C. Pretty amazing that a GM dealer would leave it at that. An OBDII code is the STARTING point in a diagnostic not the end.
Old Nov 18, 2013 | 05:41 PM
Snoopy's Avatar
donbrew....
I know what the procedure is (by the way, they also use a litmus paper test and compare it to a color chart). I want to know if the dealer did that or guessed. Seems like an unusual number, but I guess it would depend on the mixture proportions.
But I doubt even "if" he used any mixture ratio it would cause the symptoms he is expressing.....unless used for a long period of time AND the mixture did cause some corroding effect.
Old Nov 18, 2013 | 07:55 PM
Originally Posted by Snoopy
donbrew....
Sorry, I didn't see the "do you know" part of the sentence.
And, it would only apply to FlexFuel vehicle anyway. It's a 2011 so it is.
The other way would be a refractometer (however it is spelled).
But it doesn't sound like the "dealer" spent much time on it.
Old Nov 18, 2013 | 08:10 PM
https://www.chevyhhr.net/forums/showthread.php?t=44575
Thanks for replying. Yes my car is E85 capable and I always use regular gas that is 87% percent octane rated and I always get gas from the same gas station. I will be sure to check the MAF sensor to see if its working properly.
When I typed in the error code in the search tool it didnt give me any results. But thanks for pasting the link so I can find it...
Old Nov 18, 2013 | 08:13 PM
X2.....
Thanks for the info. I will do as suggested. No I don't know how the dealer determined the alcohol content in my gasoline. Apparently they must have some kind of device that they can connect to my fuel rail to get a sample.
Old Nov 18, 2013 | 08:21 PM
Wow I had no idea that code could mean all of those things. The dealer didn't mention any of those possibilities, I guess not all GM dealers are created equally.
Yes I totally agree that an OBDII code is the STARTING point in any diagnostic, but it should definitely point you in the right direction in troubleshooting a problem. But my next step is too seek out another dealership for a second opinion for sure.
Thanks for your input and for replying to my thread.
