Car still pulls after alignment
Old Sep 12, 2020 | 08:38 AM
desertrat's Avatar
I had a nagging problem with my '07 HHR. I replaced both control arms as the bushings were shot, and tie rod ends, and then had an alignment. It still pulled to the left, especially at low speeds. I swapped front tires, no change. Calipers had been previously replaced, they were not dragging. Axles and hubs were also replaced, not a surprise at 155,000 miles. But the car still pulled to the left.
The struts looked good, they had about 60,000 miles on them. So I changed them out as a last-ditch effort , and the car was like new again! No pulling at all, and it handled great. I know the strut is critical in keeping the caster angle correct, but the alignment shop said it was within specs, and the printout showed this. I guess the lesson learned is that if all else fails, take a look at the struts. They may look good and be within specs, but can still be junk.
Old Sep 12, 2020 | 09:26 AM
Good it’s fixed, could have been the top bearing plates binding with the upper coil spring plate, that can be enough to cause a pull to either side.
Old Sep 12, 2020 | 09:55 PM
It is pretty hard to test springs.
Old Sep 13, 2020 | 08:29 AM
But you will here the old rusty spring plate crunching when you turn a corner
That bearing gets sandwiched between the upper spring plate and the strut mount
This is the upper spring plate , the bottom side, crusty with rust
This is the top side where the plastic bearing lives , sandwiched in under the upper strut mount.
Old Sep 14, 2020 | 08:31 AM
desertrat's Avatar
I agree that the bearing, if seized, could prevent the steering from returning back to straight. My HHR has never been in salt, so rust and corrosion were not a factor.
slonny
Jan 6, 2020 01:57 PM
FYWW
21
Feb 26, 2019 05:53 PM
dinobass
Aug 28, 2013 05:30 PM
JAMIROBri
Apr 24, 2012 08:12 PM
twistrman
Apr 27, 2011 08:53 PM
