Car won't start and lean fuel
Old Sep 4, 2012 | 08:02 PM
Mrs.Clay's Avatar
I have a 2008 Chevy HHR LT. Started having problem with my key ignition switch last Thursday. Have to turn the key over 4-5 times before my car would start. Once started it drives fine. Then Friday the check engine light came on. Had it checked to find out that my fuel was "lean". This doesn't make any since to me. I bought the car used in May 2012. I haven't had any problems out of it up until now. Could lean fuel be that I got some bad gas? How does the power train warranty work? How long is the warranty?
Old Sep 4, 2012 | 08:16 PM
foolmoon_design's Avatar
Could be dirty maf. Could also be a faulty evap.
Old Sep 4, 2012 | 09:28 PM
"Have to turn the key over 4-5 times before my car would start. Once started it drives fine. Then Friday the check engine light came on. Had it checked to find out that my fuel was "lean". "
Sounds like you could have a fuel pump going bad.
Old Sep 5, 2012 | 12:10 AM
Mrs. Clay- Welcome !! How it works is, if any failed part is on the list, repair is FREE..
Powertrain Warranty is 5 years (from date vehicle was first titled) or 100K miles.
The build date on the drivers door sticker, is NOT the date when first titled.
Electric fuel Pump is covered..
Here's the list of everything covered, I printed mine for my 2008.
https://www.chevyhhr.net/forums/problems-service-repairs-42/07-09-10-11-powertrain-parts-coverage-list-22231/
Work4crown
Apr 9, 2013 12:09 PM
Nok817
Dec 29, 2012 11:17 AM
donbrew
Nov 28, 2012 11:31 PM
Jfidelh
May 30, 2012 05:27 PM
