Charging problem
Old Jun 22, 2024 | 06:45 PM
Notagain's Avatar
The parts store jumped the car and checked the load at the battery.
Old Jun 23, 2024 | 06:47 AM
Meanwhile, how about those 4 bolts? Have you tightened them?
Old Jun 23, 2024 | 11:59 AM
Notagain's Avatar
I did tighten the four bolts and it may have helped. I put the charger on the battery after tightening and it was using 10 amps at first but dropped to about 5 amps quicker than before.
I still can't turn the large lug on the fuse block even after tapping it to loosen the rust. I have a small butane torch I could heat it with but it's so close to the fuse block it might damage it. What else could I do to get the lug off?
Old Jun 23, 2024 | 12:52 PM
Kroil and time. Corrosion usually means a short somewhere.
Old Jun 24, 2024 | 02:33 PM
Notagain's Avatar
Wouldn't a short blow a fuse?
Old Jun 24, 2024 | 03:26 PM
Not if there is enough resistance. Every DC circuit is a potential "short", but there is resistance between the + and -.
If a module is not working right there can be a drain. Like a burned out semi-conductor.
Corrosion is the result of transfer of ions.
Old Jul 1, 2024 | 04:31 PM
Notagain's Avatar
It turns out that my starter is bad. I couldn't start the car a few days ago so I had someone tap the starter while I turned the key and it started This happened a few more times. I am in the process of putting in a new starter. Should I apply dielectric grease to the starter pigtails and/or the threaded stud?
Old Jul 1, 2024 | 04:55 PM
Not required but you could if you want to
Old Jul 1, 2024 | 05:22 PM
Notagain's Avatar
OK Thanks.
albertv
Oct 5, 2019 04:11 PM
drse
Mar 21, 2017 08:44 AM
bugo
Dec 3, 2015 04:34 PM
jack burniston
Oct 6, 2013 07:17 PM
Rain
Aug 21, 2013 02:31 PM
