Check battery syst
Old Aug 31, 2019 | 02:17 PM
M3ndoR's Avatar
Check battery syst
Guys im in deep sh** o havea check charging system in and imin middle of nowhere in serbia, my car wont even start now. I pulled the car to a local magician and he mointed the voltmeter to the box of fuses (-) and to the belt part and said its the alternator/generator, and he told me is not repairable, only teh part replacemnt.
Help me i have some serbs that want 100+ electricia job (x) euro for doin it tommowrow.
How sure can i be its the alternator.
The car had 10,3 v from the alternator on the engine on no gas pedal.
The meśage after the check chargin system was battery saving on. Then my servo went down and the car stopped.
Oh there was no battery icon when it was driven, im 1000 km from home, please help !
Maybe someone from serbia ?
Old Aug 31, 2019 | 02:57 PM
Cat Man HHR's Avatar
First off. How old is the battery ?
These cars don't like low voltage. Causes many problems.
Just for information. What is the CCA (Cold Cranking Amps) of the battery you have now ?
"The car had 10,3 v from the alternator on the engine on no gas pedal."
Are you saying the engine was running when this voltage reading was done ?
Old Aug 31, 2019 | 03:59 PM
alternator output should be about 14.2
Battery engine off should be around 12.7
I don't understand "belt part".
If I understand correctly; yes bad alternator. But check for fried wires.
Old Aug 31, 2019 | 04:51 PM
M3ndoR's Avatar
Battery since begining few years. I dont remember ifthe engine wa runing.
Old Aug 31, 2019 | 05:19 PM
M3ndoR's Avatar
I meant the oposite of the alternator (-) under the fuse box and (+) around the opposite side of the alternator
albertv
Oct 5, 2019 04:11 PM
cdmartin79
Jul 19, 2019 05:57 PM
riceman
Jul 4, 2015 06:02 PM
ruckdog60
Dec 21, 2014 08:17 AM
mark1104
Jul 8, 2014 04:57 PM
