Check charging system
Old May 9, 2016 | 07:15 PM
apalknowlie@gmail.com's Avatar
I have a 2006. He by hhr displaying a check charging system message and battery saver on.. we have replaced the battery and the alternator but I am still getting the message and it keeps draining my battery. Any suggestions??
Old May 9, 2016 | 07:51 PM
This is not sarcasm.
There is something wrong with the charging system that needs to be checked.
Old May 9, 2016 | 08:02 PM
x2 - at this point since you have replaced the obvious primary points of failure, you need someone to actually lay hands on it to run diagnostics.
and - using your email address as a member name is an open invite to spam email. If you wish to change your member name, send a PM to the administrator, 843de, and he will gladly change it for you.
Old May 9, 2016 | 08:33 PM
Welcome to the site!
Have your new battery and alternator checked out, AutoZone and most any other parts palaces do it for free.
You're gonna need to have access to the battery, for the load test to be done.
Also it's time to investigate the grounds, make sure they are clean and tight!
Here's a link to a great thread about were they are
https://www.chevyhhr.net/forums/how-...cations-56504/
riceman
Jul 4, 2015 06:02 PM
kmcrae476
May 25, 2015 11:19 PM
GDZHHR
Nov 29, 2013 12:19 PM
TDee1970
Aug 15, 2012 04:58 PM
ChiTownHHR
Jul 8, 2006 10:44 PM
