check engine light went on...
Old Jan 8, 2014 | 07:46 PM
jeff schaffer's Avatar
check engine light update part 2
Car is in Limp mode right now and the car wont move at all when put in in first gear, 2nd works fine light lag an automatic btw.
The trans shop says to drop the trans to repalce all solinods will cost around $1000 when i've got a guy that will rebuild the whole trans complete for $1300
this is nuts.
losing my mind...
jeff
Old Jan 8, 2014 | 07:47 PM
still working on the next move hope chevy dealer will help tomarrow.
To be continued...
Old Jan 9, 2014 | 07:28 AM
There is absolutely no need to start a new thread, so I moved theses 2 posts.
Please at least read responses.
Old Jan 9, 2014 | 10:03 AM
Jeff , Lucky's post does mention cold start, meaning the car is at ambient temperature and has not run for awhile, not that it's cold, however it also mentions Canada so I see your confusion , lol. Let us know how it went with the GM dealer
Old Jan 10, 2014 | 01:37 AM
Cool Bad to worse...
So we emptied the trans black fluid came out then changed to syntheic and it went black and burnt up instantly dont think just changing the solenoids
is going to cut it anyone know what a fair rebuild $ would be so i know im getting a good $ from my shop? annyone...
Old Jan 10, 2014 | 10:45 AM
Jeff.
If you drain the old fluid, then you only get about half of it out. You just added new fluid to the old burnt stuff that's still in there, most of it is in the torque convertor. It doesn't take long to mix togeather and look black again.
None the less, it does sound like your trans is shot and in need of a
rebuild/replacement.
Old Jan 13, 2014 | 08:19 AM
The proper ATF Dexron VI is a synthetic specification. If you have replaced the ATF with anything else in the past.......
How did you find that the fluid was black without draining it again?
A trans shop would be the right place to go, they could diagnose and give you an estimate, go to several for bids.
purple people eater
Sep 17, 2016 01:07 PM
flooprigger
Aug 4, 2013 08:58 AM
jmpnjoe86
Mar 10, 2013 06:13 PM
hhr856
Nov 14, 2011 12:26 PM
cruzzonn
Nov 9, 2011 08:33 AM
