Clunking issue: Solved!
Old Jan 20, 2019 | 09:48 AM
  #161
SheckyB's Avatar
I put my finger in the one on driver side bottom and the one on top passenger side could be that. ill try that But I do THANK YOU ! for Your Help and Concern. my only problem now is I get dizzy and nauseous when I go under the car uked the other day changing ox sensor Well Thanks again.
Old Jan 20, 2019 | 11:11 AM
  #162
Old Jan 20, 2019 | 12:42 PM
  #163
SheckyB's Avatar
Cant seem to Find the parts online for the motor mounts Its 2007 Manual trans Any place you reccomend? Manual seems to make all the difference.
Old Jan 20, 2019 | 12:48 PM
  #164
RockAuto has a listing
Old Jan 20, 2019 | 04:50 PM
  #165
Or on eBay https://www.ebay.com/sch/i.html?_fro...74058&_sacat=0
Old Jan 20, 2019 | 07:12 PM
  #166
Don't go cheap or you may have a failure like one of our members posted recently.
Old Jan 23, 2019 | 12:16 PM
  #167
SheckyB's Avatar
What about the one under Driver side (Front) Got a Link The one you show is Very accessible
Old Jan 23, 2019 | 12:21 PM
  #168
Here’s a part number, RockAuto has them
Old Mar 22, 2019 | 09:31 AM
  #169
Radco's Avatar
OK a older thread revival ,FYI I am Old to lol 2011 HHR LT 2.2 78k on the clock ,
Going to get the Struts (Quick Struts) and rear shocks changed ! Rides good, ,tire wear good etc ! I have been reading this thread from the beginning then skipped to the end so may have missed some things.
When I had the counter guy do my est. I believe he said a Sway Bar link was recommended as well ! Was not sure which one as it showed 1 at 11" and one at 13" .. FYI going by memory from 2 months ago :O
Looking at Monroe Shocks and Quick Struts. Not sure if going to the higher end Monroe's is worth it ???
Is using the Monroe's worth the cost ???
What brand do you use ?
Anyone know the length of the Sway Bar link on the 2011 ??? Are all 2011 the same ?
Also I am not doing the install I do have 3 garage's and my old shop mechanic to rely on :) I work PT in a Auto Parts store and they will install labor only ! So I want to have all the parts before I drop off the HHR
I am tech challenged so my wording may be way off :O
Thanks for the help !
Old Mar 22, 2019 | 10:06 AM
  #170
Sway bar end links - all use the 10" ones (actually 9.86" center to center).
Monroe Quick Struts are often used with good results.
