Clunking issue: Solved!
Old Jan 21, 2011 | 03:19 PM
  #51
bjall4jc's Avatar
Well, just thought I'd through my 2 cents in. I had the clunking issue, they replaced my intermediary shaft about 2 months ago and it went away. Now, its back, and about 10x louder than it was.
EDIT: My HHR just turned 10,000 miles last night.
Old Feb 19, 2011 | 08:24 PM
  #52
Pastor of Muppets's Avatar
I just replaced my sway bar links with the Moog ones (as everyone has suggested) today, and it is a night-and-day difference. Absolutely cured the issue 100%.
Old Feb 22, 2011 | 11:07 AM
  #53
bilko's Avatar
I replaced the end links at the end of the summer, now after replacing the front bearing assams. I saw that the sway bar mid point bushings are bad.
Did chevy use more that one size bar in 06?
I want to replace them with poly greasable bushings.[/I]
Old Feb 24, 2011 | 09:36 PM
  #54
mister hhr's Avatar
We have the clunking noise in the front of our 07 hhr 95 thousand miles we are replaceing struts and shocks next week may as well replace end links while we are at it.
Old Feb 24, 2011 | 09:43 PM
  #55
When you do the sway bar end links, don't forget the sway bar bushings. Cheap rubber from the factory and likely part of the cause.
Old Feb 25, 2011 | 01:04 AM
  #56
I would say Yes, I know the 2LT with the FE3 sport suspension & a 1" front sway bar.
IIRC the LS has a smaller bar..
I would just slide under & measure yours, to be sure what you have.
Then no mistakes..
Old Feb 25, 2011 | 09:35 AM
  #57
diskullman's Avatar
I measured mine from above, you can see it plain as day in the engine compartment.
Old Feb 25, 2011 | 06:38 PM
  #58
Goose's Avatar
Are these covered under the 36K warranty or the 100K warranty...the hub bearing assembly fell under the 100K so just wondering
Goose
Old Feb 26, 2011 | 04:07 PM
  #59
voigtsga's Avatar
moved to separate thread
Old Mar 3, 2011 | 09:19 PM
  #60
surfer54's Avatar
Cluncking Noise
Front-End Clunking= GM junk...but I love the stupid car....my mechanic checked all the ball joints etc nothing, said maybe it's the stabilizer bar link...and then said "it's no Lexus"
