Clunking issue: Solved!
FE3 codes
Thank you very much for all your help!!
I have another issue. It's been around for a while, but I've been busy and it's not as annoying as the other noise was..yet. Tricky part is, none of my tricks to make it audible(while under the hood) are working. I can easily make it happen while driving. It's a thump, but not similar to the last with the end link. It happens just about all the time around here, with small holes, dips, etc. I can make it audible if I swerve side to side and it clunks pretty good.
I cannot however, make it do it while the car is standing still. Whether it be in park and just turn the wheel erratically, or getting out and shaking the car. Crawling under the car and prying around on things resulted in nothing as well. I do not believe it to be end links, because as I said, the noise is a totally different type of clunk. I do not believe it to be CV's because when those go south, it would normally make noise if I made a full, flat footed turn. I also do not place it at the steering shaft because to me, clearly it is an outside issue and not an inside issue.
It sounds more like a ball joint or a tire rod, but I can't confirm because I cannot reproduce the noise unless I am driving.
Hmmmm...
Well, if your problem were the end links you can have some one shake the car and you can physically grab the end link and it will stop. That is how I singled out my end link the first time.
As for me, I can not get the sound to appear by shaking or at a stop. So I will have to wait. But, I don't have my heart set on end links anyway, because as i said, it is a completely different tone than last time.
Sway bar end link - clunk
Can anyone tell me if changing the sway bar end links to the moog part with grease fittings STOP that clunk for good? Don't wanna pay more for a part that still has to be changed out every year. Have an 08 and had them changed out every year under warrenty and now the dealer is telling me I am responsible!?!
Sway bar noise
Hey there Greybeard999, We have changed the sway bar bushings, end links, intermediate stering shaft, complete stering colume, stering linkage from colume to rack. I don't understand. When bringing it into the Dealership that many times you would think they would want to investigate instead of throwing parts at it and pushing me out the dooor?. What a nightmare for my first ever brand new vehicle! Was mine made on a Monday?
