Clutch/accelerator/neutral safety/cruise control issues
Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
Randy
I seem to recall that spring was on a back order status at one time ?
Or am I thinking of the clutch pedal pivot bushings ?
It may have been, years ago. I had no issue getting it 4 years ago, and this order is already shipped, should be here by Saturday. It's a kit, with the spring and bushings.
Originally Posted by DrLoch
That's it no clutch except to get it rolling
I can't imagine how much practice it would take to be able to learn that!
Got the parts on Saturday as promised. The install takes maybe 5 minutes. Anyone whose clutch pedal hangs up, or is replacing their spring, should have a look at this repair how-to, see if you may have a similar issue. This shows why I had the issue with the original spring.
