Code p0172
Old Sep 10, 2017 | 04:18 PM
Curious53's Avatar
I just went to Auto zone got a regular thermostat for hhr 2011 and I have 68890 miles
Old Sep 10, 2017 | 05:02 PM
Thermostat is the LAST item to consider as the problem.
I would look for vacuum leaks first; if you have a hard start condition.
You already cleaned the MAF
Test the fuel pressure; I am thinking the most likely cause in your case is the fuel pump/regulator.
Old Sep 10, 2017 | 05:09 PM
MAF connections could be loose, definitely the wrong thermostat.
That'll throw a P0128 code eventually, but wait for it.
Old Sep 10, 2017 | 05:13 PM
Curious53's Avatar
I haven't done anything else to the car now the light is out again if anything like before it comes back on after I drive it for awhile.
Old Sep 10, 2017 | 05:47 PM
Carry on, if it illuminates again, have the code confirmed again. Don't assume it's the same.
Old Sep 10, 2017 | 05:53 PM
Curious53's Avatar
Gotcha thanks
Old Sep 10, 2017 | 06:34 PM
The on again/off again nature is why my guess is the fuel pressure regulator in the fuel pump.
A faulty MAF, especially wiring, has it's own set of codes.
With no other symptoms noted the other causes are remote possibilities.
A friend of mine threw money and parts at his P0172 for a couple of years before the fuel pump finally died; oddly enough no P0172 after it was replaced with no other work done.
Old Sep 10, 2017 | 06:44 PM
Curious53's Avatar
Wow thanks thats good to know
KENDADK
May 12, 2017 01:12 AM
Warriorpluto
Mar 4, 2017 05:58 PM
gbynum
Nov 7, 2014 10:05 AM
manualtrans2.4
Jul 8, 2014 01:58 AM
SmootHHR
Nov 19, 2013 01:26 AM
