Control arm stuff
Old Feb 1, 2023 | 09:14 PM
hhrumadbruh's Avatar
Originally Posted by rj_rs_ss_350
yes, that's fe5!
Old Feb 6, 2023 | 02:46 PM
PulpFriction's Avatar
Originally Posted by Oldblue
Same procedure for changing the bushings and ball joints, they are not the same physically as each other.
https://www.chevyhhr.net/forums/gene...ushings-63331/
https://youtu.be/B8H_whW1vpc
That video is a confidence booster. I like his "X" grind on the heads of the rivets. But I'm reporting him to the SPCA (Society for the Prevention of cruelty to Aluminum.) Also I'm not convinced that the ball joint really needed to be replaced. Sacrificed for education. Also, I desperately wanted those bolts to point up. Don't know if that would interfere with anything, tho.
Old Feb 6, 2023 | 06:32 PM
The three ball joint bolts point down, No interference.
Old Feb 6, 2023 | 11:04 PM
chevcat's Avatar
Ball joint swap
Unable to find the LCA #25930724 at any GM supplier, was wondering if I could
use the Mevotech CMS50174 LCA and just replace the ball joint with one from
OTTP?
Old Feb 7, 2023 | 07:07 AM
Why not replace the ball joint on your LCA’s and change the rear bushings with Moog K200285 problem solvers.
To answer your question, yes
Old Feb 7, 2023 | 08:11 AM
^^^Pretty sure that's what I'd do.^^^
Old Feb 7, 2023 | 08:31 PM
chevcat's Avatar
Thanks for the info!
Old Feb 8, 2023 | 08:46 AM
You’re welcome.
Kimberly Brooks Campbell
Aug 12, 2020 05:22 PM
slonny
Dec 23, 2017 08:45 AM
alexrckid
11
Feb 26, 2012 07:46 PM
fastsuv
Jan 30, 2012 12:01 PM
hhrfreek
Nov 24, 2011 02:19 PM
