Coolant DIC reads hot
Old Aug 28, 2015 | 01:46 PM
rockettlauncher's Avatar
New to me 2008 HHR LT2 with 43K miles. The coolant display reads 212-230 when pulling hills in AZ with 110+ ambient temp. The needle gauge moves from 1 mark below halfway to almost halfway. My other GM cars have a large dead-band for the needle gauge so it always stays in the center. My question, does the needle gauge and coolant temp readout get their input from the same sensor? I was thinking I may have a bad sensor if they do not. No loss of coolant and no boil over. I backed down in speed when the temp reached 230 and it dropped to the low 220's. and continued to drop after the hill. Around town it runs 205-212 in stop and go traffic with the AC on. Under no load/coasting it drops to 192-196 at city speeds. Any help is appreciated.
Old Aug 28, 2015 | 02:05 PM
Snoopy's Avatar
Depending on the "hills" you are speaking of, it may be normal. For example, running up to Flagstaff on I-17 and encountering Sunset Point I had experienced the same temps as you. In fact many Arizona people have witnessed the same readings in the same area.....and others as well.
The analog temp gauge is a worthless piece of equipment as far as I an concerned. I have never seen it climb above the half way point and my digital temperature was indicating 235. I drove (the vehicle is now sold) my HHR with the DIC display on the digital engine temperature ALL THE TIME.....it's kind of a piece of mind.
One of the other "things" I have noticed (and also been told) is the water pump is inadequate for AZ temperatures, especially at Interstate speeds. If you lower the speed 5-10 mph from the 70 or 75 you'll recognize slightly lower temps (5-10 degrees). I've experimented with this 100's of times and it has worked every time.
Now if you are speaking of the gradual hills experienced on the Interstate through the valley, I withdraw all the statements except the lowering of speed and the function of the analog gauge.
Oh I might add.....have you checked the level of the coolant and if it had been changed as suggested by the Owners Manual. If not, you are overdue.
Old Aug 28, 2015 | 02:11 PM
The transmission fluid may be adding heat to the coolant in those conditions. You might consider an ATF cooler.
Old Aug 28, 2015 | 02:19 PM
'08 ? Time for a new Tstat and Dexcool
Old Aug 28, 2015 | 06:33 PM
Thx for the feedback. Coolant level is fine and looks new, however I will change the coolant and thermostat for a known baseline. I will check into a trans cooler.
Old Aug 28, 2015 | 07:36 PM
Be sure to get a GM AC Delco 180 degree T-stat and use proper 50/50 Dexcool.
Search results for: '180 degree thermostat'
lil tank
Dec 30, 2013 08:57 PM
Cheko0602
Nov 30, 2013 10:49 AM
mongo
Nov 18, 2010 11:22 AM
plumb34
Jul 6, 2010 12:53 AM
07_HHR
Aug 8, 2008 02:26 PM
