Cooling fan help
Cooling fan help
The other day i stopped at bank and when I came back out it started kinda weird. Anyways ac and cooling fan quit working. I swapped the cooling fan relay no difference. I jumped pin 30 to pin 87 (have 12 volts there) and fan still doesnt run.. Figured no biggie, fans go bad. So I replaced it today, didnt fix my issue.
With the pins 30 and 87 jumped I still I still dont have power to the connector for the cooling fan. I have no continuity from pin 87 to the plug at the fan motor though I do have continuity to one pin of the connector to ground, so I dont think its a ground issue. Fuses are good. At a loss, appreciate any help anyone can give.
I found this in the way back machine
https://www.chevyhhr.net/forums/gene...g-fan-c-58973/
Hope this helps
Hope this helps
SDV
Sep 30, 2009 07:13 AM
