Cranks, but no start
Old Jun 21, 2018 | 09:40 AM
Originally Posted by Oldblue
Rocks clapped together, front timing chain guide broke and the valves hit pistons, resulting in low compression.
Timing chain replacement might resolve TTR problem but a bent valve or two might just have trashed the engine. Pulling the head will tell you that answer.
This is my thought also. A leak down test would tell a lot.
Old Jun 21, 2018 | 12:28 PM
But if the valves are bent , there’s gonna be no pressure to leak down. I’m more of a visual kinda guy, after all these years I’ve learned, Murphy’s law, and there are no short cuts!
Old Jun 21, 2018 | 12:32 PM
If they're bent, they won't seal, and you'll hear(or feel) the air from the compressor escaping through the intake or exhaust. Or is there something I'm not thinking of? Or are you thinking of a compression test?
Old Jun 21, 2018 | 12:50 PM
Nope, I’m thinking , why waste time on another test, pull the head , visually ensure no bent valves, just replacing the timing chain with bent valves is taking up valuable time and could possibly poke a hole in a piston.
These Ecotec’s are close tolerance , but don’t tolerate bad timing chain problems.
ScreweDriver
Dec 14, 2017 11:35 AM
Jacob Watson
Dec 5, 2017 08:47 AM
Rocky Aranda
Apr 14, 2017 10:22 PM
mrmarkuSS
Dec 22, 2016 05:23 PM
Kelly Nicole
Feb 4, 2016 09:54 AM
