Cranks, fuel pump not running…
yeah loose ground for fuel pump was the issue, it runs now. the ground point under the right tail lamp and some insulation, 10mm nut, probably a good thing to check since it could leave you stranded. i got lucky, this happened 1 day after a 5.5 hours trip home for halloween
