Cruise Control Will NOT Engage
Old 05-14-2019, 08:21 PM
hperrenot's Avatar
Okay, I know this Is a common problem and I have read every forum there is about this issue.
I have a 2006 HHR and the cruise control will not engage; The indicator light on the steering wheel does illuminate.
The third brake light does have brand new NON LED bulb and all do illuminate.
I have replaced the brake switch on the brake petal and tested the other switch next to it.
The car is a five speed so I have also verified that the clutch switch does work (otherwise the car wouldn't start)
I feel like this problem has been covered at least a hundred times but I have different symptoms it seems.
ALSO, my car will not accept any new key fobs. I am friends with a very reputable locksmith (15 years experience) and he has used 4 different programmers to pair a fob...nothing will work.
Even tried different fobs.The car does beep twice to ensure that the pairing mode has been initiated on the car and is ready for pairing...but no remote will pair. I have done everyting besides spend the $30 from Chevrolet on a remote and let them bend me over on the install price.
PLEASE tell me someone has had either of these problems and found a working solution that wont require me to pole dance to pay for.
All help is appreciated that leads to a solution to my vehicles issue.
hperrenot is offline
Old 05-14-2019, 11:38 PM
Have you checked to see if any OBD error codes are downloadable?
whopper is offline
Old 05-15-2019, 12:24 AM
There might be 2 switches on the clutch
RJ_RS_SS_350 is offline
Old 05-15-2019, 06:08 AM
fastsuv's Avatar
I believe you are correct, there are 2 switches on the clutch. One is for the starter circuit and the other for everything else.
Steve
fastsuv is offline
Old 05-15-2019, 07:51 AM
DrLoch's Avatar
Key fobs, Tech2. I just deleted all and programmed 3 for one of my HHR's. Others have had different results but most have had to do it with a Tech2.
DrLoch is offline
Old 05-15-2019, 08:38 AM
Have you tried a battery lobotomy to reset the computers?
Oldblue is offline
Old 05-15-2019, 09:42 AM
hperrenot's Avatar
I have. Only code shown is for intermittent coolant below tempature. but the check engine light isn’t ON
hperrenot's Avatar
Please explain
Old 05-15-2019, 09:43 AM
hperrenot's Avatar
Steve
Both are functioning and making contact as they should. As stated in original posting.
Old 05-15-2019, 09:45 AM
Originally Posted by hperrenot
Please explain
Disconnect the NEGATIVE battery post for 15 - 30 minutes, then reconnect it. Do NOT close the hatch else it will be a pain to get it open again - just throw a towel over the latch to keep it from closing and locking.
whopper is offline
Quick Reply: Cruise Control Will NOT Engage
