Diagnostics Port Help
I've checked every fuse in the car and they are all ok, but that did make me think of something else. The cigarette lighter in the front doesnt work and I'm guessing they are on the same circuit. When I bought the car, the previous owner had a XM receiver and some other stuff installed and he left the power cord and antenna in it. I bet there is a cut/disconnected wire somewhere. I'll do some more checking and let you know what I find
I had this happen to mine, but had a blown #29 fuse due to bad lighter element shorting to ground.
On my pickup the CEL came on, no power on the diagnostics port, replaced the fuse and it cleared the CEL light. Test the fuse for power at each side. There might be a fuse box problem.
Thanks for all the help. After checking multiple things, I found a wire that was broke/cut/disconnected under the dash. Luckily it was just hanging and never contacted anything. Ive had this car for a year and a half now so there is no telling how long its been like that. Anyway, problem solved and i can finally use my bluetooth OBD2 and get all my diagnostics on my phone. Isnt technology great?!
deedz
Aug 10, 2013 12:29 PM
