Does this sound like a rod knock?
Old Jan 31, 2023 | 02:56 PM
hhrumadbruh's Avatar
I think I'm going to disagree. The HPFP is more like a chatter. Here's mine.
https://youtube.com/shorts/vx1sV0cQnhg?feature=share
That is what mine used to sound like. But it would only make the click about twice a second...had a noticeable pause between clicks...
Old Jan 31, 2023 | 03:11 PM
They sound the same to me different microphones.
Old Jan 31, 2023 | 03:16 PM
They aren't the same my new noise is deeper.
Old Jan 31, 2023 | 04:27 PM
The thick oil is not helping, the tolerances these engines run are too close for thick oil. The oil pumps can’t pull the oil out of the sump. You’re killing your cams and mains and rod bearings .
The cams don’t have bearings they run in aluminum caps in the cylinder head.
The oil sump can’t bring out the thick Lucas when it’s cold, you have oil starvation for a few seconds on startup
Old Jan 31, 2023 | 04:34 PM
There could be gunk built up like this suggests
Old Jan 31, 2023 | 06:12 PM
Bad news. Knock is dependent on rpm. But it's intermittent at 1500 rpm and goes away at 2k rpm.
Old Jan 31, 2023 | 07:14 PM
Did you change the oil yet? Is it oil starved or you gonna freshen up the bearings, rings and cylinder head?
Old Jan 31, 2023 | 07:35 PM
greg8453's Avatar
While idling in park do a quick snap of the throttle. Tell us what you think.
Old Jan 31, 2023 | 07:43 PM
I did not. I don't know if it's oil starved. Are the 2.0's different than 2.2 or 2.4? No issues with 10-40 and 1 quart of Lucas oil stabilizer in my 2010 LT with 2020k and had it since 40k.
I really don't want to go that far but...if you think I should...I will buy a engine puller and just rebuild the whole thing I guess.
I will do it tomorrow. Gonna try to finish some stuff tonight before my bed time.
Old Feb 1, 2023 | 07:58 AM
You’re just lucky with your 2.4.
I’m out!
BadLILSS
Jun 26, 2021 09:06 PM
firemangeorge
May 8, 2017 08:39 PM
NappiiRoots
Feb 23, 2016 01:05 PM
Gol10dr
10
Mar 15, 2012 11:54 PM
jbbadboy
Jul 8, 2009 07:30 PM
