Driver door wont open to do the door handle repair
My inside door handle broke off. To fix it the door needs to be open to get to the parts. I started to disassemble the inside door panel with the door un opened.. is there a spot where I can put a tool to trigger the inside so I can get the door open for the repair? The outside door handle was vandalized and just hanging off so I will have to fix that also.
The outside handle connects to the latch via a rod. You might be able to see it. yank it up.
The inside handle doesn't work? That connects via a cable.
No bypass that I know of. Maybe a body shop or locksmith would have a trick.
SeanDavey
Feb 16, 2020 10:32 PM
Bystrakps
Aug 8, 2014 10:40 PM
