Drivers side turn signal / brake light
Old Nov 16, 2017 | 09:40 PM
Lonwane's Avatar
DonBretw, It's been a while but I traced the yellow wire all the way back to the BCM connecter and the wire is good ( minimal resistance with an ohm meter) Do you know which pin from the BCM to check? Also how does the harness disconnect from the BCM? I would hate to break it as I am quite capable of that.
Old Nov 16, 2017 | 10:22 PM
Are you doing all of this testing with the engine on?
Pin A9 on the BCM connector X3. IIRC; you pull the lock lever, maybe that one is bolted down.
Old Nov 17, 2017 | 08:27 AM
Lonwane's Avatar
Testing was done with power OFF. I was just testing the wire to check continuity. Thanx for the info. I will check the BCM output tomorrow.
Old Dec 3, 2017 | 04:17 PM
Lonwane's Avatar
Finally took the plunge to find what I didn't want to. There is no power for the turn signal coming out of the BCM. Time to replace. Any opinions?
Old Dec 3, 2017 | 05:20 PM
Cat Man HHR's Avatar
Sorry just had to do this.
https://driversed.com/driving-inform...d-signals.aspx
Old Dec 3, 2017 | 05:26 PM
Lonwane's Avatar
Thanx. I almost forgot what I Like about this site
Old Dec 3, 2017 | 05:37 PM
Hmm. Back in post #1 you stated you could "fix it" by jiggling the wire harness.
If so, then maybe your recent testing at the BCM was inaccurate. What I mean is, did you test the other BCM outputs that correspond to the lights that are working ?
Just don't want you to condemn the BCM if maybe it was a test error( still basing my opinion on your "fix' from before.)
Old Dec 3, 2017 | 05:48 PM
Since it is highly unlikely the BCM would break, just that one function, I would start looking toward the multi function switch.
I just don't know how a computer could forget one 0 or 1. Old fashioned flasher; yes. I guess it could, but pretty unlikely.
The multi function switch (turn signal stalk) has 2 connectors, this is the one for the turn signals. I think the signal sent is "ground". So, when turned to right pin H should have continuity to ground, otherwise it should be open.
Old Dec 3, 2017 | 10:43 PM
Lonwane's Avatar
Thanx for all the help. My latest test was to activate the emergency flasher and insert a test light probe in the BCM X3 A9 and no light, I then moved the probe to A12 and the test light flashed. I used the same connections while pressing the brake pedal and got the same results. I'm stumped.
Old Dec 4, 2017 | 08:49 AM
So, there are also wires under the hood to look for. Any work under there lately?
I cannot see anything in the diagrams and schematics I have.
