Drivers side turn signal / brake light
Old Apr 24, 2019 | 08:40 PM
  #51
Originally Posted by donbrew
I think we are talking the brake/turn light.
Hmm. OK. Earlier Lonwane's post said tail lights. Now I see he edited that part to say tail/brake lights. Not really sure which lights he's talking about so I'll just watch this thread as an observer.
Old Apr 24, 2019 | 10:53 PM
  #52
Lonwane's Avatar
It's the brake / turn signal light.
Which brings to question, Could low voltage be an issue?
I haven't checked voltage at the battery but when I was doing some investigating I noticed that the tail light had less than 12 volts at the socket. (Motor not running)
The battery is only 8 months old, which doesn't mean anything, just wondering if.
That still doesn't explain only the driver side issue but I have to remove all that could be wrong.
Old Apr 25, 2019 | 08:44 AM
  #53
Less than 12 V on both sides? Like the PO installed a resistor and didn't remove it?
Even with the motor not running it should be over 12V.
The left brake/turn lights are the yellow wire at pin A9 on connector C3 on the BCM.
Ignore the red circle, on this diagram the use J3 and X3 instead of C3, just to confuse everybody.
Old Oct 13, 2019 | 09:20 AM
  #54
Lonwane's Avatar
Hey Gang,
After over one year of it works it stopped woking, it works, it stopped working, ( insert jokes here) I finally broke down and took Toughie to the dealer for repair.
Turns out a wire was broken as had been recommended in a n earlier responce.
Good news is the issue has been resolved and I now have ALL my brake lights.
Now onto the suspension.
Old Oct 13, 2019 | 11:03 AM
  #55
Silverfox's Avatar
Whew !!!
I am very happy you got the mystery resolved. You really have a ton of Resolve.
It was gratifying to see the guys stick with you through this very long effort.
Suspension NEXT ?????
I Gotta Buy a Pair of Reading Glasses for that one.
Good Luck.....
Silverfox
Old Oct 13, 2019 | 04:48 PM
  #56
Lonwane's Avatar
Front struts and steering rack. Gotta find the cause of the wobbling steering wheel upon braking.
Old Oct 13, 2019 | 05:10 PM
  #57
LCAs was my experience then struts.
Old Oct 13, 2019 | 06:30 PM
  #58
Lonwane's Avatar
Already done LCA,s and motor mounts. I'll also do the front hubs when I do the struts.
Old Oct 13, 2019 | 07:12 PM
  #59
phrog fixer's Avatar
What size load resistor is needed for L.E.D. conversion?
Old Oct 13, 2019 | 08:50 PM
  #60
Does that have something to do with this thread? I must have missed it.
Did you think you were starting a new thread?
