Drum Wheel Stud replacement
Don't bang on it! bearing damage will occur. There is a tool made to push it out, basically 2 fingers on the back side and a screw on the outside. Or, remove the hub get a good surface to support the flange and wail away. Or, you may be needing new rear bearings anyway ~$95 a pair on Ebay, 4 bolts each (I did my last one in casual clothing before I went to work).
RustyNCA
Maintenance and Upkeep
13
Apr 26, 2014 02:25 PM
